Ga door naar hoofdinhoud
How to Apple Wireless Keyboard Reset
Wat je nodig hebt
Video overzicht
  1. How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: stap 1, afbeelding 1 van 3 How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: stap 1, afbeelding 2 van 3 How to Apple Wireless Keyboard Reset, Switch off the Apple Wireless Keyboard: stap 1, afbeelding 3 van 3
    • Switch off the keyboard by holding down the power button for at least 3 seconds
    • Open "System Preferences...", "Bluetooth".
    How can you do that if your keyboard isn't connected?
    Jo Maz - Antwoord
  2. How to Apple Wireless Keyboard Reset: stap 2, afbeelding 1 van 3 How to Apple Wireless Keyboard Reset: stap 2, afbeelding 2 van 3 How to Apple Wireless Keyboard Reset: stap 2, afbeelding 3 van 3
    • Remove Your Apple Wireless Keyboard
  3. How to Apple Wireless Keyboard Reset: stap 3, afbeelding 1 van 2 How to Apple Wireless Keyboard Reset: stap 3, afbeelding 2 van 2
    • Follow the steps to pair Your Keyboard
    In my magic keyboard the tab and caps lock keys keep going on and off, randomly. I do not understand why and how to fix that. When they don't work I try resetting resetting the keyboard, but to no avail. Then suddenly they sort of wake up and work again. How's that?
    Pupo Santi - Antwoord
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
191.182 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.519 handleidingen geschreven
4 opmerkingen
I bought a wireless keyboard at a flea market. When pairing I was able to enter all numbers, but the "Enter" key does not react. Is there some way to test the button?
Rainer Stumpf - Antwoord
Same for me. The problem was the enter key: there are 2 switches down the key but only the top one is pressed and this is broken. I removed the key, put a plastic spacer on the second switch and reassembled the key, all ok now.
Nemo Capitano -
Pairing my A1255 to my 2011 MacBook Pro, after many press and hold button attempts to reset, it was unsuccessful. Until I brought both the laptop and the keyboard to a insulated staircase of the building so no other Bluetooth devices are present, the two connected.
Vu Linh - Antwoord
ho provato a resettarla ma niente da fare funziona solo parzialmente .l’ho collegata all’iPad 11 pro e funziona perfettamente
victor
Vittorio Panebianco - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 66
Afgelopen 7 dagen: 401
Afgelopen 30 dagen: 2,047
Altijd: 79,398
