Ga door naar hoofdinhoud
How to Alter a Large Dress to Fit
Wat je nodig hebt
  1. How to Alter a Large Dress to Fit, How to Alter a Large Dress to Fit: stap 1, afbeelding 1 van 1
    • Put on your dress.
    • Pinching the waistline, grab your ruler and measure from your hip.
    • This number will tell you how much you need to take in to make your dress fit.
  2. How to Alter a Large Dress to Fit: stap 2, afbeelding 1 van 1
    • Turn your dress inside out and lay it on a smooth surface.
    • Using your measurements from Step 1, measure out evenly from the seam line how much you need to take in on each side.
    • As you measure how much you take in, use the clothespins as a marker.
  3. How to Alter a Large Dress to Fit: stap 4, afbeelding 1 van 1
    • Carefully put on your dress to make sure that it fits you in the right way.
    • Now that your dress fits how you would like, carefully take it off and lay it back on a flat surface.
    • Using chalk or a pen, make a line that connects all the pins.
    • This line will be a guide for when you use the sewing machine.
  4. How to Alter a Large Dress to Fit: stap 6, afbeelding 1 van 1
    • Thread your sewing machine.
    • If you need help on how to thread the sewing machine, here is a guide on how to.
    • Carefully push your dress through and begin sewing your new seam.
  5. How to Alter a Large Dress to Fit: stap 7, afbeelding 1 van 1
    • When you're done sewing your dress, flip it so that it is right side out and put it on.
    • If there is any excess fabric, you can cut it away, leaving 1/4 of an inch of the leftover fabric by the seam.
Conclusie
This is an easy and low budget way to fix a dress that is too large. Check the tag on the dress to see how you should care for it after. It is best recommended that you let your dress air dry.
Één andere persoon heeft deze handleiding voltooid.
Viviane Dobis
145 Reputatie
1 Handleiding geschreven
Texas Tech, Team S14-G7, Cowan Fall 2020 Lid van Texas Tech, Team S14-G7, Cowan Fall 2020
TTU-COWAN-F20S14G7
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 1,063
