Ga door naar hoofdinhoud
How to Access the Internal Components of an HP 15-R011DX
Wat je nodig hebt
  1. How to Access the Internal Components of an HP 15-R011DX, Battery: stap 1, afbeelding 1 van 2 How to Access the Internal Components of an HP 15-R011DX, Battery: stap 1, afbeelding 2 van 2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. How to Access the Internal Components of an HP 15-R011DX: stap 2, afbeelding 1 van 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: stap 3, afbeelding 1 van 2 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: stap 3, afbeelding 2 van 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. How to Access the Internal Components of an HP 15-R011DX: stap 4, afbeelding 1 van 2 How to Access the Internal Components of an HP 15-R011DX: stap 4, afbeelding 2 van 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. How to Access the Internal Components of an HP 15-R011DX: stap 5, afbeelding 1 van 2 How to Access the Internal Components of an HP 15-R011DX: stap 5, afbeelding 2 van 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. How to Access the Internal Components of an HP 15-R011DX: stap 6, afbeelding 1 van 3 How to Access the Internal Components of an HP 15-R011DX: stap 6, afbeelding 2 van 3 How to Access the Internal Components of an HP 15-R011DX: stap 6, afbeelding 3 van 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. How to Access the Internal Components of an HP 15-R011DX: stap 7, afbeelding 1 van 2 How to Access the Internal Components of an HP 15-R011DX: stap 7, afbeelding 2 van 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
Conclusie
Ethan Guillotte
490 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S2G4
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 485
