Inleiding
If the hook end (male end) of your buckle is broken, it’s easy to replace. We’ll show you how in just a few easy steps.
Gereedschap
Onderdelen
In order to determine the correct buckle size, measure the webbing. The webbing illustrated here is 15 mm, so you would need a 15 mm buckle.
Follow the instructions in reverse order to finish your repair.
4 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Één commentaar
Used to use Ortlieb panniers and I have recently changes to Vaude Aqua Back Plus for some incremental additional volume and also the external pocket. I could see that it is easy to replace the male end of the buckle but I guess it could almost be the end of the bag if the female end is broken?
…or maybe you could show us as well how to fix that too, so that we could have some comfort other simply praying that this would not happen!
I have the same problem but the nylon straps are sewn on so you can’t slip a new buckle on. Is there a version available that slips on somehow?
scott - Antwoord
