Ga door naar hoofdinhoud
How do I replace a QMR Rail Hook on the hardback panel of my bike bag?
Wat je nodig hebt
  1. How do I replace a QMR Rail Hook on the hardback panel of my bike bag?, QMR Rail Hook on the hardback panel: stap 1, afbeelding 1 van 1
    • Recess for thread plate.
    • If the defective thread plate is still on the rail, it can be removed with the help of a 3 mm hex key. Use the hex key to push the thread plate into the marked section and push down.
  2. How do I replace a QMR Rail Hook on the hardback panel of my bike bag?: stap 3, afbeelding 1 van 1
    • Lift the oval rail slightly with the flathead screwdriver and replace the defective thread plate with the new one. Take care that the new oval thread plate is correctly inserted into the the rail.
  3. How do I replace a QMR Rail Hook on the hardback panel of my bike bag?: stap 4, afbeelding 1 van 1
    • Set the black oval disc on the rail at the level of the silver thread plate.
  4. How do I replace a QMR Rail Hook on the hardback panel of my bike bag?: stap 5, afbeelding 1 van 3 How do I replace a QMR Rail Hook on the hardback panel of my bike bag?: stap 5, afbeelding 2 van 3 How do I replace a QMR Rail Hook on the hardback panel of my bike bag?: stap 5, afbeelding 3 van 3
    • Position the black QMR Rail Hook on the black disc, insert the screw and tighten it using the hex key.
Eindstreep
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
VAUDE Reparaturteam
6.255 Reputatie
32 handleidingen geschreven
Vaudesport Lid van Vaudesport
Community
3 Leden
96 handleidingen geschreven
Één opmerking
Thank you! Very helpful!
Chelsea Coleman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 2,322
