Ga door naar hoofdinhoud
How To True A Bicycle Wheel
Wat je nodig hebt
Video overzicht
  1. How To True A Bicycle Wheel, How To True A Bicycle Wheel: stap 1, afbeelding 1 van 1
    • Put the rim and align into the truing stand.
  2. How To True A Bicycle Wheel: stap 2, afbeelding 1 van 1
    • Second, grab lubricant.
  3. How To True A Bicycle Wheel: stap 3, afbeelding 1 van 1
    • Notice how each nipple is void of lube. In this step add the lube to each individual nipple.
  4. How To True A Bicycle Wheel: stap 4, afbeelding 1 van 1
    • Once you have completed the previous task, loosen the truing knob.
    • This will make the truing arms open.
    • Give it a spin! The centrifical force lubes up the threads, making it easier to begin truing.
    • Notice the spoke wrenches; they will be required in our next step.
  5. How To True A Bicycle Wheel: stap 5, afbeelding 1 van 1
    • Use the truing knob to determine how fine the truing arms (red) need to be. In this case, I am truing finely down to the millimeter.
  6. How To True A Bicycle Wheel: stap 6, afbeelding 1 van 1
    • Here the spoke tool (red) will be needed. After giving it a spin, I noticed that it deviated far too much to the left. You will know this by hearing which side scrapes against the truing arm. (orange)
    • Use the spoke wrench (red) to tighten the spokes (yellow). It is good practice to tighten the spoke before and after on the side that needs truing.
    • Lastly, keep truing tire until the range of deviation is good to you. This process for a "quick-fix" can be as little as 30min-1 hour.
    • Experienced cyclists may vary from days to weeks to completely true their tire.
Conclusie
Elijah W
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 59
