Ga door naar hoofdinhoud
How To Restring a Yo-Yo
Wat je nodig hebt
  1. How To Restring a Yo-Yo, String: stap 1, afbeelding 1 van 1
    • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
    Vraag FixBot
    Voeg opmerking toe
  2. How To Restring a Yo-Yo: stap 2, afbeelding 1 van 1
    • Analyze the current state of the string.
    • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
    • If the string is damaged beyond repair, then get your new string ready.
    Vraag FixBot
    Voeg opmerking toe
  3. How To Restring a Yo-Yo: stap 3, afbeelding 1 van 1
    • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
    • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
    Vraag FixBot
    Voeg opmerking toe
  4. How To Restring a Yo-Yo: stap 4, afbeelding 1 van 1
    • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
    • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
    Vraag FixBot
    Voeg opmerking toe
  5. How To Restring a Yo-Yo: stap 5, afbeelding 1 van 1
    • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
    Vraag FixBot
    Voeg opmerking toe
  6. How To Restring a Yo-Yo: stap 6, afbeelding 1 van 1
    • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
    • This will ensure that the placement of the string is secure.
    Vraag FixBot
    Voeg opmerking toe
  7. How To Restring a Yo-Yo: stap 7, afbeelding 1 van 1
    • Screw the halves back together firmly, making sure that they are aligned correctly.
    • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
    Vraag FixBot
    Voeg opmerking toe
  8. How To Restring a Yo-Yo: stap 8, afbeelding 1 van 1
    • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
    Vraag FixBot
    Voeg opmerking toe
Conclusie
After following these steps, you will have successfully restrung your Yo-Yo.
3 andere personen hebben deze handleiding voltooid.
Mark Amirthanathan
205 Reputatie
1 Handleiding geschreven
1Gids Commentaar
nice tutorial
sdsdsds - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 103
Altijd: 6,171
