Ga door naar hoofdinhoud
How To Replace Custom-cut Adhesive For Samsung Phones
Wat je nodig hebt
  1. How To Replace Custom-cut Adhesive For Samsung Phones, How To Replace Custom-cut Adhesive For Samsung Phones: stap 1, afbeelding 1 van 1
    • Depending on your phone model, you may not need to complete certain sections of this guide. Check your adhesive kit to see what needs to be done:
    • To install the battery adhesive, follow this guide.
    • To transfer and install the fingerprint sensor and gasket, start with the next step.
    • To transfer and install the rear bezel, skip to step 5.
    • To install the back cover support adhesive, skip to step 9.
    • To install the back cover perimeter adhesive, skip to step 13.
  2. How To Replace Custom-cut Adhesive For Samsung Phones, Fingerprint sensor and gasket adhesive: stap 2, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Fingerprint sensor and gasket adhesive: stap 2, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Fingerprint sensor and gasket adhesive: stap 2, afbeelding 3 van 3
    • The following three steps show how to remove and transfer the fingerprint sensor and its gasket.
    • If your phone's fingerprint sensor and camera reside on a single rear bezel (like on the S9), you can transfer that bezel without removing the parts individually.
    • Heat an iOpener and apply it to the fingerprint sensor for one minute.
    • Use an opening tool to gently pry the fingerprint sensor at the lower seam, where it contacts the back cover.
    • Do not pry at the upper seam, which is the fingerprint gasket seam.
  3. How To Replace Custom-cut Adhesive For Samsung Phones: stap 3, afbeelding 1 van 2 How To Replace Custom-cut Adhesive For Samsung Phones: stap 3, afbeelding 2 van 2
    • If you're only replacing the fingerprint sensor and not the fingerprint sensor gasket, skip this step.
    • Use an opening tool to pry the fingerprint sensor off of the gasket.
    • Remove the colored plastic liner on the replacement gasket to expose the adhesive.
    • Carefully align and lay the fingerprint sensor onto the sticky side of the gasket.
    • Once aligned, press down firmly with your finger to bond the adhesive.
  4. How To Replace Custom-cut Adhesive For Samsung Phones: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    Koop
    • To affix the fingerprint sensor to the new back cover, use a custom cut adhesive, or line the perimeter of the sensor with double-sided tape such as Tesa tape.
    • Align the fingerprint sensor in the back cover cutout and press down firmly with your finger to bond the adhesive.
  5. How To Replace Custom-cut Adhesive For Samsung Phones, Rear bezel: stap 5, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Rear bezel: stap 5, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Rear bezel: stap 5, afbeelding 3 van 3
    • The following four steps show how to remove and transfer the rear bezel. The bezel supports the rear cameras, flash, and the fingerprint sensor (on some models).
    • Heat an iOpener and apply it to the rear bezel for a minute.
    • Starting from the outward-facing side of the back cover, push the bezel inwards with a finger to loosen the bezel from its cutout.
    • Do not push too hard, or you may bend the bezel.
    • Alternatively, you can pry around the bezel with an opening tool to loosen it from the back cover.
  6. How To Replace Custom-cut Adhesive For Samsung Phones: stap 6, afbeelding 1 van 2 How To Replace Custom-cut Adhesive For Samsung Phones: stap 6, afbeelding 2 van 2
    • Remove the bezel.
    • Use an opening tool and some high concentration isopropyl alcohol to remove any remaining adhesive residue on the bezel.
  7. How To Replace Custom-cut Adhesive For Samsung Phones: stap 7, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 7, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 7, afbeelding 3 van 3
    • Peel away the clear plastic liner from the bezel adhesive strip to expose the adhesive.
    • Carefully align the adhesive to the back cover's cutout.
    • Once aligned, press the adhesive in place with your finger.
    • Peel away the colored plastic liner from the adhesive to expose its surface.
  8. How To Replace Custom-cut Adhesive For Samsung Phones: stap 8, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 8, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 8, afbeelding 3 van 3
    • Carefully align and set the bezel over the adhesive.
    • Squeeze the bezel perimeter with your fingers to set the adhesive.
    • Clean the bezel glass with a microfiber cloth.
  9. How To Replace Custom-cut Adhesive For Samsung Phones, Back cover support adhesive: stap 9, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Back cover support adhesive: stap 9, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Back cover support adhesive: stap 9, afbeelding 3 van 3
    • The following four steps show how to install the back cover support adhesive(s).
    • If you're replacing the fingerprint sensor or the rear bezel, be sure to complete those tasks first.
    • Figure out how the support strip aligns with the surfaces by matching the adhesive strip's contours with the adhesive residue and the phone frame.
    • Generally speaking, the adhesive side that's covered by a clear plastic liner should affix to the back cover, while the side that's covered by a colored liner should affix to the phone frame.
    • Use an opening tool and high concentration isopropyl alcohol to remove all adhesive residue from the phone frame.
    • If you're re-using the back cover, remove all adhesive residue from the back cover.
    • Do not use metal tools as they will scratch the back cover's coating.
  10. How To Replace Custom-cut Adhesive For Samsung Phones: stap 10, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 10, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 10, afbeelding 3 van 3
    • Peel the clear liner off of the support adhesive strip to expose the adhesive.
    • Carefully lay the strip sticky side up on top of the phone frame, being careful not to touch the sticky surface.
    • Align the adhesive strip on the phone frame so that the adhesive contours matches the frame's.
    • If you have two small support strips, repeat the process for both strips.
  11. How To Replace Custom-cut Adhesive For Samsung Phones: stap 11, afbeelding 1 van 2 How To Replace Custom-cut Adhesive For Samsung Phones: stap 11, afbeelding 2 van 2
    • Carefully lower the back cover onto the exposed support strips. This ensures that the adhesive is transferred onto the back cover in its proper position.
  12. How To Replace Custom-cut Adhesive For Samsung Phones: stap 12, afbeelding 1 van 2 How To Replace Custom-cut Adhesive For Samsung Phones: stap 12, afbeelding 2 van 2
    • Remove the back cover.
    • Use fingers to press the support adhesive firmly onto the back cover.
    • Peel away the colored liner to expose the adhesive.
  13. How To Replace Custom-cut Adhesive For Samsung Phones, Perimeter adhesive: stap 13, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Perimeter adhesive: stap 13, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones, Perimeter adhesive: stap 13, afbeelding 3 van 3
    • The remaining steps show how to install the back cover perimeter adhesive.
  14. How To Replace Custom-cut Adhesive For Samsung Phones: stap 14, afbeelding 1 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 14, afbeelding 2 van 3 How To Replace Custom-cut Adhesive For Samsung Phones: stap 14, afbeelding 3 van 3
    • The adhesive is very sticky—you normally have one chance to apply it properly, so be careful as you handle the adhesive.
    • Peel away the clear liner from the perimeter adhesive strip to expose the adhesive.
    • Hold the strip by its tabs and carefully line up a long edge of the adhesive to the edge of the back cover.
    • Set the adhesive onto the back cover and press it onto the cover with your fingers.
    • Peel away the colored liner from the perimeter adhesive strip to expose the adhesive.
    • Make sure the adhesive doesn't peek over the cover edge, or it won't properly seal the device.
    • At this point, the back cover is prepped for sealing. Be sure to test your phone's functionality before sealing the phone.
  15. How To Replace Custom-cut Adhesive For Samsung Phones: stap 15, afbeelding 1 van 2 How To Replace Custom-cut Adhesive For Samsung Phones: stap 15, afbeelding 2 van 2
    • To seal the phone, align and set the back cover onto the phone frame.
    • Apply pressure to the phone perimeter with your fingers.
    • Place some books on top of the back cover for half an hour to help the adhesive bond.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Eindstreep
124 andere personen hebben deze handleiding voltooid.
Arthur Shi
252.726 Reputatie
526 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
14 opmerkingen
The flex cable for the fingerprint sensor is so short and delicate that it’s fiendishly difficult to locate and snap in. You only have a very narrow gap between the back cover and the phone, it wants to jump out of position if you misalign at all, and you can’t reach under there with normal size fingers. Not only that, it’s done with the rear cover adhesive in place so if that touches, it sticks.
I got it snapped on, and the flex cable broke at the same moment. So, no fingerprint sensor for me. Also, the new back cover arrived broken. If it was usable, the way to do it IMHO is to attach the flex cable first, then push the fingerprint sensor assembly on to the new back cover adhesive (it goes on from behind), then close the back cover.
WILLIAM SCHIER - Antwoord
Hey William,
If you bought the back cover from iFixit, please contact our support team here and we will get a replacement sorted out for you!
Arthur Shi -
P.S. I got the battery and cover because the old cover was warped and separated, figured may as well replace the battery in a 2-year-old phone. Turns out, the battery was swollen and huge and it had pushed the back cover open. Not a good situation. So if your back cover is coming off, suspect that battery.
P.P.S. The fingerprint sensor flex cable connector probably could be manipulated into position with the tweezers from the tool kit and pressed down into place with the plastic screwdriver thingy, Just hover the back cover over it with your third hand (or a helper).
Will the phone still be water-resistant after this repair?
Shai Toledano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 39
Afgelopen 7 dagen: 327
Afgelopen 30 dagen: 1,359
Altijd: 84,768
