Ga door naar hoofdinhoud
How To Repair An Overheating D-LINK DIR-655 Wireless Router
Wat je nodig hebt
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 1, afbeelding 1 van 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 1, afbeelding 2 van 2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 2, afbeelding 1 van 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 2, afbeelding 2 van 2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 3, afbeelding 1 van 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 3, afbeelding 2 van 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 3, afbeelding 3 van 3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 4, afbeelding 1 van 1
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 5, afbeelding 1 van 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 5, afbeelding 2 van 2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 6, afbeelding 1 van 1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 7, afbeelding 1 van 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 7, afbeelding 2 van 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 7, afbeelding 3 van 3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 8, afbeelding 1 van 1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: stap 9, afbeelding 1 van 1
    • Wipe away any dust from the the vents to ensure proper airflow.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Chance Daniel
263 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-6, Green Fall 2015 Lid van Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 Leden
3 handleidingen geschreven
Één opmerking
Fixed my unit :-)
larry_wollen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 5,464
