Ga door naar hoofdinhoud
How To Repair A Rip In Chiffon Fabric
Wat je nodig hebt
    1. How To Repair A Rip In Chiffon Fabric, How To Repair A Rip In Chiffon Fabric: stap 1, afbeelding 1 van 1
      • Locate the rip in the fabric.
      Vraag FixBot
      Voeg opmerking toe
    2. How To Repair A Rip In Chiffon Fabric: stap 2, afbeelding 1 van 1
      • Trim off any fraying at the tear.
      • Fold the fabric in half at the tear and cut off the fraying. This makes it easier to clip the smaller frayed fibers as well.
      Vraag FixBot
      Voeg opmerking toe
    3. How To Repair A Rip In Chiffon Fabric: stap 3, afbeelding 1 van 1
      • Fold the fabric in half at the rip so that the raw edges are right side together.
      Vraag FixBot
      Voeg opmerking toe
    4. How To Repair A Rip In Chiffon Fabric: stap 4, afbeelding 1 van 1
      • Find a permanent fabric adhesive.
      Vraag FixBot
      Voeg opmerking toe
    5. How To Repair A Rip In Chiffon Fabric: stap 5, afbeelding 1 van 1
      • Carefully apply the adhesive to the raw edges.
      Vraag FixBot
      Voeg opmerking toe
    6. How To Repair A Rip In Chiffon Fabric: stap 6, afbeelding 1 van 1
      • Keep the edges together until almost dry.
      Vraag FixBot
      Voeg opmerking toe
    7. How To Repair A Rip In Chiffon Fabric: stap 7, afbeelding 1 van 1
      • Then lay the cloth flat and push the edges together to make sure the ends stay together.
      • Let the adhesive dry completely.
      • At this point, if your tear/repair is large, you can find a patch that can cover the repair and glue it on.
      • Avoid ironing on the patch. This may cause even more damage to fabric as this material is already very delicate.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Now the damage done to your fabric should be contained and the material should be restored to working order. Hope this helped!
Manasa Dintakurthi
145 Reputatie
1 Handleiding geschreven
1Gids Commentaar
What would you do if it is a large tear? Someone stepped on my dress and has torn it towards the hem
Serena - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 264
Altijd: 19,147
