Ga door naar hoofdinhoud
How To Patch A Hole In The Wall
Wat je nodig hebt
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: stap 1, afbeelding 1 van 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: stap 1, afbeelding 2 van 3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: stap 1, afbeelding 3 van 3
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: stap 2, afbeelding 1 van 2 How To Patch A Hole In The Wall: stap 2, afbeelding 2 van 2
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: stap 3, afbeelding 1 van 1
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: stap 4, afbeelding 1 van 3 How To Patch A Hole In The Wall: stap 4, afbeelding 2 van 3 How To Patch A Hole In The Wall: stap 4, afbeelding 3 van 3
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: stap 5, afbeelding 1 van 1
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: stap 6, afbeelding 1 van 1
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Conclusie
Now your wall should be looking as good as new!
3 andere personen hebben deze handleiding voltooid.
Joseph Garcia
293 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-2, Green Fall 2015 Lid van Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Leden
8 handleidingen geschreven
Één opmerking
I suggest using a sanding sponge or block in step 6
Dennis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,472
