Ga door naar hoofdinhoud
How To Open A Desktop Hard Drive
Wat je nodig hebt
  1. How To Open A Desktop Hard Drive, Remove The Front Screws: stap 1, afbeelding 1 van 2 How To Open A Desktop Hard Drive, Remove The Front Screws: stap 1, afbeelding 2 van 2
    • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
  2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: stap 2, afbeelding 1 van 2 How To Open A Desktop Hard Drive, Removing The Hidden Screws: stap 2, afbeelding 2 van 2
    • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
    • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
  3. How To Open A Desktop Hard Drive: stap 3, afbeelding 1 van 2 How To Open A Desktop Hard Drive: stap 3, afbeelding 2 van 2
    • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
  4. How To Open A Desktop Hard Drive: stap 4, afbeelding 1 van 1
    • Gently remove the cover.
    • Do NOT do what I did, please.
  5. How To Open A Desktop Hard Drive: stap 5, afbeelding 1 van 1
    • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
Conclusie
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
10 andere personen hebben deze handleiding voltooid.
gamer_Kat
391 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 136
Altijd: 1,750
