Ga door naar hoofdinhoud
How To Hem Pants With Double-Sided Fabric Tape
Wat je nodig hebt
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: stap 1, afbeelding 1 van 1
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: stap 2, afbeelding 1 van 1
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: stap 3, afbeelding 1 van 1
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: stap 4, afbeelding 1 van 1
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: stap 5, afbeelding 1 van 1
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: stap 6, afbeelding 1 van 1
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: stap 7, afbeelding 1 van 1
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: stap 8, afbeelding 1 van 1
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: stap 9, afbeelding 1 van 1
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: stap 10, afbeelding 1 van 1
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: stap 11, afbeelding 1 van 1
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: stap 12, afbeelding 1 van 1
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
Conclusie
You don't need a sewing machine to hem a pair of overly long pants.
Allison
205 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 61
Altijd: 194
