Ga door naar hoofdinhoud
How To Fix A Wicker Chair Seat
Wat je nodig hebt
  1. How To Fix A Wicker Chair Seat, How To Fix A Wicker Chair Seat: stap 1, afbeelding 1 van 2 How To Fix A Wicker Chair Seat, How To Fix A Wicker Chair Seat: stap 1, afbeelding 2 van 2
    • Soak the reed in a bowl of room temperature water for 15 minutes.
    • It should bend without snapping.
  2. How To Fix A Wicker Chair Seat: stap 2, afbeelding 1 van 2 How To Fix A Wicker Chair Seat: stap 2, afbeelding 2 van 2
    • Identify the broken pieces; you will need to remove the whole row.
  3. How To Fix A Wicker Chair Seat: stap 3, afbeelding 1 van 2 How To Fix A Wicker Chair Seat: stap 3, afbeelding 2 van 2
    • Using pliers or your hands, gently remove the broken pieces.
    • The old reeds will be brittle and will simply snap off.
    • Reed material is fragile; be careful not to remove more than you need to.
  4. How To Fix A Wicker Chair Seat: stap 4, afbeelding 1 van 3 How To Fix A Wicker Chair Seat: stap 4, afbeelding 2 van 3 How To Fix A Wicker Chair Seat: stap 4, afbeelding 3 van 3
    • Weave the reed through the perpendicular pieces, alternating over and under. Begin by passing the reed over one perpendicular and under the next, going across the chair from one side to the other.
    • Pull the reed through to the end, leaving out about two inches.
  5. How To Fix A Wicker Chair Seat: stap 5, afbeelding 1 van 3 How To Fix A Wicker Chair Seat: stap 5, afbeelding 2 van 3 How To Fix A Wicker Chair Seat: stap 5, afbeelding 3 van 3
    • When you have completed a few passes, return to the beginning of your project and find the two inches of reed left unwoven.
    • Wrap the end of the reed around the rail twice.
    • Take the remaining reed and weave it into a gap in the existing weaving; it should stay in place.
    • Continue weaving the long end of the reed.
  6. How To Fix A Wicker Chair Seat: stap 6, afbeelding 1 van 2 How To Fix A Wicker Chair Seat: stap 6, afbeelding 2 van 2
    • Once you reach the end of the row, wrap the reed around the rail twice.
  7. How To Fix A Wicker Chair Seat: stap 7, afbeelding 1 van 2 How To Fix A Wicker Chair Seat: stap 7, afbeelding 2 van 2
    • For your next row, feed the reed in alternate directions.
    • Continue this weaving pattern until the broken section is repaired.
    • Depending on the size of your project, the reed may dry during the repair process. If this happens, gather up what hasn’t already been woven and soak it in water until the reed is pliable again, around 15 minutes.
  8. How To Fix A Wicker Chair Seat: stap 8, afbeelding 1 van 1
    • Once you reach the end, cut a tail around 2 inches long with the scissors.
  9. How To Fix A Wicker Chair Seat: stap 9, afbeelding 1 van 1
    • Find a gap in the existing weaving and weave the end through; it should stay in place.
  10. How To Fix A Wicker Chair Seat: stap 10, afbeelding 1 van 1
    • Enjoy your repaired wicker chair seat!
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Olivia
199 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-3, Andersen Winter 2025 Lid van UC Davis, Team 1-3, Andersen Winter 2025
UCD-ANDERSEN-W25S1G3
3 Leden
1 handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 25
Altijd: 102
