Ga door naar hoofdinhoud
How To Fix A Loose Bicycle Pedal And Check For Damage
Wat je nodig hebt
  1. How To Fix A Loose Bicycle Pedal And Check For Damage, How To Fix A Loose Bicycle Pedal And Check For Damage: stap 1, afbeelding 1 van 1
    • Flip the entire bicycle upside down, balancing the weight on the seat and handle bars.
    • This will keep the bicycle stable while you work on it.
  2. How To Fix A Loose Bicycle Pedal And Check For Damage: stap 2, afbeelding 1 van 3 How To Fix A Loose Bicycle Pedal And Check For Damage: stap 2, afbeelding 2 van 3 How To Fix A Loose Bicycle Pedal And Check For Damage: stap 2, afbeelding 3 van 3
    • You will need an Allen Wrench or a Smart Wrench for this repair.
    • If you are using an Allen Wrench, insert the head of the wrench into socket located on the pedal arm.
    • If you are using a Smart Wrench, place the jaws on the nut located between the pedal and pedal arm.
    • Loosen the pedals by turning the right pedal counterclockwise and the left pedal clockwise.
    • Remove the pedal from the socket.
  3. How To Fix A Loose Bicycle Pedal And Check For Damage: stap 3, afbeelding 1 van 2 How To Fix A Loose Bicycle Pedal And Check For Damage: stap 3, afbeelding 2 van 2
    • Check the socket and bolt for rust and worn threads.
    • If you notice damages like rust or worn threads, you will need to refer to a separate repair guide specific to the type of damage.
    • If you do not see any damage, continue to Step 4.
  4. How To Fix A Loose Bicycle Pedal And Check For Damage: stap 4, afbeelding 1 van 3 How To Fix A Loose Bicycle Pedal And Check For Damage: stap 4, afbeelding 2 van 3 How To Fix A Loose Bicycle Pedal And Check For Damage: stap 4, afbeelding 3 van 3
    • Place the pedal back in the socket and tighten it until it is secure.
    • To tighten the pedals, turn the right pedal clockwise and the left pedal counterclockwise.
    • Once you feel resistance, turn the pedal about 1/8 of a rotation further to properly tighten it.
    • DO NOT use excessive force when you are tightening the pedal. This can lead to difficulty removing the pedal in the future.
    Thanks for the information
    Pratham Shah - Antwoord
Conclusie
If both pedals need tightening follow the steps again, remembering to turn the opposite directions for tightening and loosening.
9 andere personen hebben deze handleiding voltooid.
Thomas Paulsen
218 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-1, Green Winter 2015 Lid van Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Leden
7 handleidingen geschreven
5 opmerkingen
Yes, I agree, it's very nice way to fix pedals.
Praska - Antwoord
Would you be able to tell me how to fix a locked up bike
Hughes Zass - Antwoord
Wenn das Rad auf dem Kopf steht, ist das linke Pedal rechts und umgekehrt.
Klaus Giezek - Antwoord
My crank arm constantly comes loose, although I tightened it. I go to the bike repair store near my house, and they say that the bearing of the bottom bracket is worn. To fix this, I need to replace it with a new one, grease the new component, and tighten the bicycle crank.
Bruno John - Antwoord
Some reasons that crank arm keeps coming loose can happen, such as: the bolts are loose and damaged; incorrect installation; the bearing is damaged; the spindle is wiped out; An unfitting bottom bracket,...
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 215
Altijd: 65,852
