Ga door naar hoofdinhoud
How To Fix A Hole In Khaki Pants
Wat je nodig hebt
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: stap 1, afbeelding 1 van 1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: stap 2, afbeelding 1 van 1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: stap 3, afbeelding 1 van 1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: stap 4, afbeelding 1 van 1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: stap 5, afbeelding 1 van 2 How To Fix A Hole In Khaki Pants: stap 5, afbeelding 2 van 2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: stap 6, afbeelding 1 van 2 How To Fix A Hole In Khaki Pants: stap 6, afbeelding 2 van 2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: stap 7, afbeelding 1 van 1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: stap 8, afbeelding 1 van 1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: stap 9, afbeelding 1 van 1
    • Now put your khaki pants on because they are now wearable again and practically new!
Conclusie
Now your old ripped pants look practically new and you can begin wearing them again.
6 andere personen hebben deze handleiding voltooid.
Calvin Roth
291 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-1, Green Fall 2015 Lid van Cal Poly, Team 17-1, Green Fall 2015
CPSU-GREEN-F15S17G1
4 Leden
5 handleidingen geschreven
5 opmerkingen
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Antwoord
and 100% maching
Iam shafik i can't do it's and 100% maching
What about if you’re in school and your pants rip?
EMMA MILLER - Antwoord
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 143
Altijd: 51,465
