Ga door naar hoofdinhoud
How To Convert An iMac Into An External Monitor
Wat je nodig hebt
    • Read and follow the iMac Intel 20" EMC 2105 and 2118 Display Replacement guide, and remove your screen completely.
    • Flip the screen over, placing it on a towel to keep it safe. Locate the manufacturer's sticker on the back of the screen, which should contain the screen's Model Number
    • The screen used in this particular iMac 20" A#### EMC#### is an LG-brand model-LM201W01, though yours may be different.
    • Search either AliExpress.com or Ebay.com using the search phrase “Your-Screen-Model-Number Control Board”.
    • If your iMac is a 20", they should be around $30-$40. If 24", $60-$80.
    • Order the video driver board for your screen. It will probably ship from Asia, and take 2-3 weeks to get to you.
    • It probably will not come with a power supply. This is normal. Most video control boards require 12v 5A power supplies. You may have one in your spare electronics bin, so check there before buying one: Old routers, PC laptops, etc may have compatible power supplies.
    • placeholder
    • Follow X guide for complete iMac disassembly.
    • Placeholder for info about build
    • conception phase.
    • #show a pic of mine when it was done
    • Insert wisdom here.
Conclusie
Olympia Mac Repair
946 Reputatie
3 handleidingen geschreven
6Gids Commentaar
As my 2009 24” iMac just died (third, and maybe final, drive failure), I am very eager to see this completed.
Can you comment on the differences between available video control boards/ inverters?
Paul K - Antwoord
It’s over a year since Paul K (above) asked if this page could be completed. I’d also be keen to see it. Any chance?
C Bonney - Antwoord
Hi, will this page be completed? I would love to mod my 2011 iMac
Adrien Martinez - Antwoord
I have news. I normally use my old iMac as an external monitor with my macbook pro, connecting it via the firewire port and adapter.
I had to use the SwitchResX app to get a decent screen size and experienced only very sluggish performance.
Today i discovered that you can get far better results with native macOs stuff. Doing:
System Settings -> Displays -> Show resolutions as list -> Show all resolutions
works like a charm, with a lag that is very acceptable. I have no idea when this feature showed up.
It has been a long wait, but thank you apple.
BRo - Antwoord
Can you do this with a Mac (27-inch, Late 2012)?
Thomas Hilleras - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 575
Altijd: 22,756
