Inleiding
Will your Hover-1 Ultra not power up, preventing you from riding it? If you face this problem, it can be fixed with a simple replacement of the power button on your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to help remove the button
Wat je nodig hebt
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the hoverboard.
Carefully remove the shell, lifting directly up.
To reassemble your device, follow the instructions for step 1 in reverse order.
Één andere persoon heeft deze handleiding voltooid.
