Inleiding
Is your Hover-1 Ultra not charging to full battery, or not powering up at all? If you are experiencing these problems, it can be fixed with a very simple replacement of the charging port of your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to remove the port
Wat je nodig hebt
Orient the hoverboard so that the pads are facing down.
With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
Carefully remove the shell, lifting directly up.
To reassemble your device, follow the instructions for step 1 in reverse order.
3 andere personen hebben deze handleiding voltooid.
