Ga door naar hoofdinhoud
Hover-1 Titan Right Gyroscope Replacement
Wat je nodig hebt
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: stap 1, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: stap 1, afbeelding 2 van 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: stap 2, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: stap 3, afbeelding 1 van 3 Hover-1 Titan Right Gyroscope Replacement: stap 3, afbeelding 2 van 3 Hover-1 Titan Right Gyroscope Replacement: stap 3, afbeelding 3 van 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: stap 4, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: stap 4, afbeelding 2 van 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: stap 5, afbeelding 1 van 3 Hover-1 Titan Right Gyroscope Replacement: stap 5, afbeelding 2 van 3 Hover-1 Titan Right Gyroscope Replacement: stap 5, afbeelding 3 van 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: stap 6, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement: stap 6, afbeelding 2 van 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: stap 7, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement: stap 7, afbeelding 2 van 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: stap 8, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement: stap 8, afbeelding 2 van 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: stap 9, afbeelding 1 van 2 Hover-1 Titan Right Gyroscope Replacement: stap 9, afbeelding 2 van 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: stap 10, afbeelding 1 van 1
    • Cut the cable tie and unplug the remaining wires.
Conclusie
Jessica Ouyang
619 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G4, White Fall 2018 Lid van Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Leden
10 handleidingen geschreven
Één opmerking
Where can I get the circuit boards for the left and right ?
jfsucher - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 1,132
