Ga door naar hoofdinhoud
Hover-1 Titan Power Button Replacement
Wat je nodig hebt
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: stap 1, afbeelding 1 van 2 Hover-1 Titan Power Button Replacement, Bottom Right Panel: stap 1, afbeelding 2 van 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Power Button Replacement: stap 2, afbeelding 1 van 2 Hover-1 Titan Power Button Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Power Button Replacement: stap 3, afbeelding 1 van 3 Hover-1 Titan Power Button Replacement: stap 3, afbeelding 2 van 3 Hover-1 Titan Power Button Replacement: stap 3, afbeelding 3 van 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Power Button Replacement, Power Button: stap 4, afbeelding 1 van 2 Hover-1 Titan Power Button Replacement, Power Button: stap 4, afbeelding 2 van 2
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  5. Hover-1 Titan Power Button Replacement: stap 5, afbeelding 1 van 3 Hover-1 Titan Power Button Replacement: stap 5, afbeelding 2 van 3 Hover-1 Titan Power Button Replacement: stap 5, afbeelding 3 van 3
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  6. Hover-1 Titan Power Button Replacement: stap 6, afbeelding 1 van 2 Hover-1 Titan Power Button Replacement: stap 6, afbeelding 2 van 2
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  7. Hover-1 Titan Power Button Replacement: stap 7, afbeelding 1 van 3 Hover-1 Titan Power Button Replacement: stap 7, afbeelding 2 van 3 Hover-1 Titan Power Button Replacement: stap 7, afbeelding 3 van 3
    • Pull the power button out of the panel.
    • Replace the power button.
Conclusie
Alexander Pham
221 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G4, White Fall 2018 Lid van Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 556
