Ga door naar hoofdinhoud
Hover-1 Titan Left Gyroscope Replacement
Wat je nodig hebt
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: stap 1, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: stap 1, afbeelding 2 van 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: stap 2, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: stap 3, afbeelding 1 van 3 Hover-1 Titan Left Gyroscope Replacement: stap 3, afbeelding 2 van 3 Hover-1 Titan Left Gyroscope Replacement: stap 3, afbeelding 3 van 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: stap 4, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: stap 4, afbeelding 2 van 2
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: stap 5, afbeelding 1 van 3 Hover-1 Titan Left Gyroscope Replacement: stap 5, afbeelding 2 van 3 Hover-1 Titan Left Gyroscope Replacement: stap 5, afbeelding 3 van 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: stap 6, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 6, afbeelding 2 van 2
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: stap 7, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 7, afbeelding 2 van 2
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: stap 8, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 8, afbeelding 2 van 2
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: stap 9, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 9, afbeelding 2 van 2
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: stap 10, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 10, afbeelding 2 van 2
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: stap 11, afbeelding 1 van 2 Hover-1 Titan Left Gyroscope Replacement: stap 11, afbeelding 2 van 2
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: stap 12, afbeelding 1 van 1
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
Conclusie
Jessica Ouyang
619 Reputatie
4 handleidingen geschreven
Cal Poly, Team S15-G4, White Fall 2018 Lid van Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Leden
10 handleidingen geschreven
2 opmerkingen
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Antwoord
Where do you buy the board?
eden11 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 1,152
