Ga door naar hoofdinhoud
Hover-1 Superstar Speaker Replacement
Wat je nodig hebt
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: stap 1, afbeelding 1 van 3 Hover-1 Superstar Speaker Replacement, Bottom Case: stap 1, afbeelding 2 van 3 Hover-1 Superstar Speaker Replacement, Bottom Case: stap 1, afbeelding 3 van 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Speaker Replacement: stap 2, afbeelding 1 van 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
  4. Hover-1 Superstar Speaker Replacement: stap 4, afbeelding 1 van 1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
  5. Hover-1 Superstar Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the speaker from its port.
Conclusie
Keegan
632 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 262
