Inleiding
If your Nomad doesn't play audio even while booting up, your speaker assembly may be damaged. Follow this guide to replace the speaker assembly in your Hover-1 Nomad.
Wat je nodig hebt
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Remove the two 13mm Phillips #1 screws in the corners of the speaker assembly circuit board.
Één andere persoon heeft deze handleiding voltooid.
