Ga door naar hoofdinhoud
Hover-1 Nomad Outer Shell Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Hover-1 Nomad Outer Shell Replacement, Outer Shell: stap 1, afbeelding 1 van 3 Hover-1 Nomad Outer Shell Replacement, Outer Shell: stap 1, afbeelding 2 van 3 Hover-1 Nomad Outer Shell Replacement, Outer Shell: stap 1, afbeelding 3 van 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Outer Shell Replacement: stap 2, afbeelding 1 van 3 Hover-1 Nomad Outer Shell Replacement: stap 2, afbeelding 2 van 3 Hover-1 Nomad Outer Shell Replacement: stap 2, afbeelding 3 van 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Outer Shell Replacement: stap 3, afbeelding 1 van 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Outer Shell Replacement: stap 4, afbeelding 1 van 2 Hover-1 Nomad Outer Shell Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Samuel Frazee
1.015 Reputatie
7 handleidingen geschreven
Cal Poly, Team S15-G1, White Fall 2018 Lid van Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 54
