Inleiding
If your Hover-1 Nomad has major electrical issues, one of the gyroscope sensor boards may be damaged. You can follow this guide to remove and replace the two circuit boards in your Nomad. The circuit boards control the sensors, motors, lights, and speaker in the hoverboard.
For your safety, discharge your battery below 25% before disassembling your hoverboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Wat je nodig hebt
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Cut the two zip ties around the bundle of wires with cutting pliers.
Disconnect the following wires connecting the circuit boards to the sensors and motors:
Disconnect the white connectors by pinching the tab and pulling up on the connectors.
Disconnect the black connectors by pulling the two sides apart.
Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Any idea were can i buy the motherboard for this hover.thanks
Where can I buy these
