Ga door naar hoofdinhoud
Hover-1 Maverick Motor Wheel Replacement
Wat je nodig hebt
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: stap 1, afbeelding 1 van 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: stap 1, afbeelding 2 van 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: stap 2, afbeelding 1 van 2 Hover-1 Maverick Motor Wheel Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: stap 3, afbeelding 1 van 2 Hover-1 Maverick Motor Wheel Replacement: stap 3, afbeelding 2 van 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: stap 4, afbeelding 1 van 2 Hover-1 Maverick Motor Wheel Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: stap 5, afbeelding 1 van 2 Hover-1 Maverick Motor Wheel Replacement, Motor: stap 5, afbeelding 2 van 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: stap 6, afbeelding 1 van 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Conclusie
Piper Feldman
409 Reputatie
4 handleidingen geschreven
Cal Poly, Team S2-G2, White Winter 2020 Lid van Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 465
