Inleiding
This guide for the Hover-1 Maverick guides users in replacing the central bearing in their device. The central bearing controls the two sides of the hoverboard allowing it to rotate separately. A symptom of having a non-functioning central bearing is if the device is unable to balance. Users will need to disconnect the battery along with wires in order to replace the central bearing.
Wat je nodig hebt
Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
Remove the shell from the hoverboard. The central bearing is located in the center.
