Ga door naar hoofdinhoud
Hover-1 Matrix Pad Replacement
Wat je nodig hebt
  1. Hover-1 Matrix Pad Replacement, Pad: stap 1, afbeelding 1 van 2 Hover-1 Matrix Pad Replacement, Pad: stap 1, afbeelding 2 van 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: stap 2, afbeelding 1 van 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: stap 3, afbeelding 1 van 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: stap 4, afbeelding 1 van 2 Hover-1 Matrix Pad Replacement: stap 4, afbeelding 2 van 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: stap 5, afbeelding 1 van 3 Hover-1 Matrix Pad Replacement: stap 5, afbeelding 2 van 3 Hover-1 Matrix Pad Replacement: stap 5, afbeelding 3 van 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: stap 6, afbeelding 1 van 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
Conclusie
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Één andere persoon heeft deze handleiding voltooid.
Jici Zhuang
362 Reputatie
2 handleidingen geschreven
UC Davis, Team S7-G2, Lore Fall 2018 Lid van UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 346
