Ga door naar hoofdinhoud
Hover-1 Liberty Bottom Cover Replacement
Wat je nodig hebt
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: stap 2, afbeelding 1 van 2 Hover-1 Liberty Bottom Cover Replacement: stap 2, afbeelding 2 van 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 1 van 3 Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 2 van 3 Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Conclusie
Patrick Bacon
411 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G2, White Fall 2018 Lid van Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Leden
4 handleidingen geschreven
2 opmerkingen
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Antwoord
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 3,053
