Ga door naar hoofdinhoud
Hover-1 Liberty Battery Replacement
Wat je nodig hebt
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: stap 2, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: stap 3, afbeelding 1 van 3 Hover-1 Liberty Battery Replacement: stap 3, afbeelding 2 van 3 Hover-1 Liberty Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: stap 5, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: stap 6, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: stap 7, afbeelding 1 van 3 Hover-1 Liberty Battery Replacement: stap 7, afbeelding 2 van 3 Hover-1 Liberty Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Bacon
411 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G2, White Fall 2018 Lid van Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 2,450
