Ga door naar hoofdinhoud
Hover-1 Horizon Wheel/Motor Replacement
Wat je nodig hebt
  1. Hover-1 Horizon Wheel/Motor Replacement, Base Plate: stap 1, afbeelding 1 van 2 Hover-1 Horizon Wheel/Motor Replacement, Base Plate: stap 1, afbeelding 2 van 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Wheel/Motor Replacement: stap 2, afbeelding 1 van 2 Hover-1 Horizon Wheel/Motor Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Wheel/Motor Replacement: stap 3, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 3, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 3, afbeelding 3 van 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 3 van 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Wheel/Motor Replacement: stap 5, afbeelding 1 van 2 Hover-1 Horizon Wheel/Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Wheel/Motor Replacement: stap 6, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 6, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 6, afbeelding 3 van 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Wheel/Motor Replacement: stap 7, afbeelding 1 van 2 Hover-1 Horizon Wheel/Motor Replacement: stap 7, afbeelding 2 van 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Wheel/Motor Replacement: stap 8, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 8, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 8, afbeelding 3 van 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Wheel/Motor Replacement: stap 9, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 9, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 9, afbeelding 3 van 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: stap 10, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: stap 10, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: stap 10, afbeelding 3 van 3
    • Remove the four 30mm Hex #6 screws.
    • Lift away the silver bracket and set it to the side.
  11. Hover-1 Horizon Wheel/Motor Replacement: stap 11, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 11, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the first clip by squeezing the latch that hold the clips together while pulling apart.
    • Disconnect the second clip by squeezing the tab while pulling the clip apart.
  12. Hover-1 Horizon Wheel/Motor Replacement: stap 12, afbeelding 1 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 12, afbeelding 2 van 3 Hover-1 Horizon Wheel/Motor Replacement: stap 12, afbeelding 3 van 3
    • Detach the remaining three connections by pulling them apart.
  13. Hover-1 Horizon Wheel/Motor Replacement: stap 13, afbeelding 1 van 2 Hover-1 Horizon Wheel/Motor Replacement: stap 13, afbeelding 2 van 2
    • Remove the wheel by lifting it away from the base with both hands.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Casey Winans
324 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G6, White Fall 2018 Lid van Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 542
