Inleiding
Are your wheels experiencing resistance while turning? This is a guide to show you how to check and replace the wires that connect the wheel to the motherboard. This guide requires a Phillips #2 and a Phillips #1 screwdriver, and a 6 mm hex key.
Wat je nodig hebt
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
