Ga door naar hoofdinhoud
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
Wat je nodig hebt
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: stap 1, afbeelding 1 van 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 2, afbeelding 1 van 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 3, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 3, afbeelding 2 van 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 4, afbeelding 1 van 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: stap 5, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: stap 5, afbeelding 2 van 2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 6, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 6, afbeelding 2 van 2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 7, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 8, afbeelding 1 van 1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 9, afbeelding 1 van 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 9, afbeelding 2 van 3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 9, afbeelding 3 van 3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 10, afbeelding 1 van 1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 11, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 11, afbeelding 2 van 2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 12, afbeelding 1 van 2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 12, afbeelding 2 van 2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: stap 13, afbeelding 1 van 1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Aaron Teh
442 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G6, White Fall 2018 Lid van Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Leden
7 handleidingen geschreven
Één opmerking
where can I get the replacement parts?
Rob Sayles - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 110
Altijd: 5,173
