Ga door naar hoofdinhoud
Hover-1 Folding E-Scooter Rear Wheel Replacement
Wat je nodig hebt
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: stap 1, afbeelding 1 van 2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: stap 1, afbeelding 2 van 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 2, afbeelding 1 van 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 2, afbeelding 2 van 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 2, afbeelding 3 van 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 3, afbeelding 1 van 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 4, afbeelding 1 van 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 5, afbeelding 1 van 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 5, afbeelding 2 van 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 5, afbeelding 3 van 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: stap 6, afbeelding 1 van 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Conclusie
Luke Imai
133 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G5, White Fall 2018 Lid van Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Leden
5 handleidingen geschreven
2 opmerkingen
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Antwoord
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 51
Altijd: 5,335
