Ga door naar hoofdinhoud
Hover-1 Folding E-Scooter Brake Switch Replacement
Wat je nodig hebt
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: stap 1, afbeelding 1 van 1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: stap 2, afbeelding 1 van 2 Hover-1 Folding E-Scooter Brake Switch Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: stap 3, afbeelding 1 van 3 Hover-1 Folding E-Scooter Brake Switch Replacement: stap 3, afbeelding 2 van 3 Hover-1 Folding E-Scooter Brake Switch Replacement: stap 3, afbeelding 3 van 3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
Conclusie
Brittani Kealoha
251 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G5, White Fall 2018 Lid van Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Leden
5 handleidingen geschreven
6 opmerkingen
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - Antwoord
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - Antwoord
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - Antwoord
Looking new break switch.where we will get?. please reply.
Vitesh - Antwoord
Looking for a throttle switch. Know where I can find one?
Mara - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 37
Altijd: 4,768
