Ga door naar hoofdinhoud
Hover-1 Folding E-Scooter Brake Pad Replacement
Wat je nodig hebt
  1. Hover-1 Folding E-Scooter Brake Pad Replacement, Rear Wheel: stap 1, afbeelding 1 van 2 Hover-1 Folding E-Scooter Brake Pad Replacement, Rear Wheel: stap 1, afbeelding 2 van 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 2, afbeelding 1 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 2, afbeelding 2 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 2, afbeelding 3 van 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 3, afbeelding 1 van 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 4, afbeelding 1 van 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 5, afbeelding 1 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 5, afbeelding 2 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 5, afbeelding 3 van 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 6, afbeelding 1 van 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
  7. Hover-1 Folding E-Scooter Brake Pad Replacement, Brake Pad: stap 7, afbeelding 1 van 2 Hover-1 Folding E-Scooter Brake Pad Replacement, Brake Pad: stap 7, afbeelding 2 van 2
    • Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to reassemble.
    • There are also two nuts that secure the screws.
  8. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 8, afbeelding 1 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 8, afbeelding 2 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 8, afbeelding 3 van 3
    • Wobble to remove the brake step.
  9. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 9, afbeelding 1 van 2 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 9, afbeelding 2 van 2
    • Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
    • Twist the screwdriver clockwise to secure the screws.
  10. Hover-1 Folding E-Scooter Brake Pad Replacement: stap 10, afbeelding 1 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 10, afbeelding 2 van 3 Hover-1 Folding E-Scooter Brake Pad Replacement: stap 10, afbeelding 3 van 3
    • Remove the brake pad.
Conclusie
Meagan Chan
112 Reputatie
1 Handleiding geschreven
Cal Poly, Team S15-G5, White Fall 2018 Lid van Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Leden
5 handleidingen geschreven
Één opmerking
Hello, I have a hoverboard 1 scooter and I've charged it and it started going a couple days ago and then I came home and put it up and plugged it up for a couple hours and went to take off on it yesterday to go to a couple appointments and it would not go when I pushed off on it i only weight 128lbs so I know it's not my weight but how long do I normally charge it or should charge it without messing the battery pack up because I took it to a friend who is an electrician that I bought it from and he said he didn't know what could be wrong with it for me to call around to the scooter shops but no one has returned my calls and I need help with this matter asap if someone could please help me oh and also the scooter cuts on and shows 13 on the screen and as I push it it'll change to 94 like how am I walking 94mph I don't get it but the headlight works cause when I cut it on its bright and it cuts off when I hold the button but I also wanted to know if there was a reset button on this hoverboard 1 scooter
Olivia Joshua Samuel-Bolt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 2,768
