Ga door naar hoofdinhoud
Inleiding
If you are ever in a position where the trucks on your Coast are broken or malfunctioning it is very important to replace them. Replace the trucks will ensure the coast is able to function at its highest potential.
  1. In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board. Using the pick tool to puncture the grip tape and reveal the screws. The board should look like this.
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  3. Once all four screws have been revealed, locate the socket wrench and the Phillips #1  screwdriver in the wrench handle. Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw. Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  4. Remove the nuts from the bottom of the board. Slide the unwanted trucks off the screws. The black rubber spacer will stay on the board.
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Conclusie
Alaina Limon
97 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 5
Altijd: 83
