Ga door naar hoofdinhoud
Hover-1 Coast Board Battery Replacement
Wat je nodig hebt
  1. Hover-1 Coast Board Battery Replacement, Board Battery: stap 1, afbeelding 1 van 3 Hover-1 Coast Board Battery Replacement, Board Battery: stap 1, afbeelding 2 van 3 Hover-1 Coast Board Battery Replacement, Board Battery: stap 1, afbeelding 3 van 3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Board Battery Replacement: stap 2, afbeelding 1 van 3 Hover-1 Coast Board Battery Replacement: stap 2, afbeelding 2 van 3 Hover-1 Coast Board Battery Replacement: stap 2, afbeelding 3 van 3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Board Battery Replacement: stap 3, afbeelding 1 van 3 Hover-1 Coast Board Battery Replacement: stap 3, afbeelding 2 van 3 Hover-1 Coast Board Battery Replacement: stap 3, afbeelding 3 van 3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Board Battery Replacement: stap 4, afbeelding 1 van 3 Hover-1 Coast Board Battery Replacement: stap 4, afbeelding 2 van 3 Hover-1 Coast Board Battery Replacement: stap 4, afbeelding 3 van 3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Where can you order a replacement battery?
Phil - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 605
