Ga door naar hoofdinhoud
Hover-1 Chrome Left Gyroscope Sensor Board Replacement
Wat je nodig hebt
  1. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Hover-1 Chrome Disassembly: stap 1, afbeelding 1 van 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 2, afbeelding 1 van 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 3, afbeelding 1 van 2 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 3, afbeelding 2 van 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 1 van 3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 2 van 3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: stap 4, afbeelding 3 van 3
    • Disconnect the speaker cable.
    • Disconnect the cable that travels to the other sensor board.
  5. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 5, afbeelding 1 van 3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 5, afbeelding 2 van 3 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the smaller connector midway on the cable.
    • Disconnect the larger connector midway on the cable.
  6. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 12mm Phillips #2 screws securing the sensor board.
  7. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 7, afbeelding 1 van 2 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: stap 7, afbeelding 2 van 2
    • Locate the five solder locations on the underside of the gyroscope sensor board.
    • Plug in soldering iron and wait for the tip tip to reach its target temperature.
    • Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the sensor board.
    • Be aware of where the tip of the soldering iron is at ALL times. Put on safety glasses before picking up the soldering iron. Turn on a fan and face it towards the device to vent harmful fumes away from the solderers face.
Conclusie
Nick McGuire
551 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G1, White Fall 2018 Lid van Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 1,098
