Ga door naar hoofdinhoud
Hover-1 Chrome LED Headlights Replacement
Wat je nodig hebt
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: stap 1, afbeelding 1 van 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: stap 2, afbeelding 1 van 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: stap 3, afbeelding 1 van 2 Hover-1 Chrome LED Headlights Replacement: stap 3, afbeelding 2 van 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: stap 4, afbeelding 1 van 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: stap 4, afbeelding 2 van 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: stap 4, afbeelding 3 van 3
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: stap 5, afbeelding 1 van 2 Hover-1 Chrome LED Headlights Replacement: stap 5, afbeelding 2 van 2
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: stap 6, afbeelding 1 van 3 Hover-1 Chrome LED Headlights Replacement: stap 6, afbeelding 2 van 3 Hover-1 Chrome LED Headlights Replacement: stap 6, afbeelding 3 van 3
Conclusie
Nick McGuire
551 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G1, White Fall 2018 Lid van Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 174
