Ga door naar hoofdinhoud
Hover-1 Chrome Battery Replacement
Wat je nodig hebt
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: stap 1, afbeelding 1 van 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: stap 2, afbeelding 1 van 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: stap 3, afbeelding 1 van 2 Hover-1 Chrome Battery Replacement: stap 3, afbeelding 2 van 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: stap 5, afbeelding 1 van 2 Hover-1 Chrome Battery Replacement: stap 5, afbeelding 2 van 2
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick McGuire
551 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G1, White Fall 2018 Lid van Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 627
