Ga door naar hoofdinhoud
Hover-1 Charger Outer Shell Replacement
Wat je nodig hebt
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: stap 1, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement, Outer Shell: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: stap 2, afbeelding 1 van 1
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: stap 3, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 3, afbeelding 2 van 2
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: stap 4, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 4, afbeelding 2 van 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: stap 5, afbeelding 1 van 3 Hover-1 Charger Outer Shell Replacement: stap 5, afbeelding 2 van 3 Hover-1 Charger Outer Shell Replacement: stap 5, afbeelding 3 van 3
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: stap 6, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 6, afbeelding 2 van 2
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: stap 7, afbeelding 1 van 1
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: stap 8, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 8, afbeelding 2 van 2
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: stap 9, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 9, afbeelding 2 van 2
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: stap 10, afbeelding 1 van 1
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: stap 11, afbeelding 1 van 2 Hover-1 Charger Outer Shell Replacement: stap 11, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: stap 12, afbeelding 1 van 3 Hover-1 Charger Outer Shell Replacement: stap 12, afbeelding 2 van 3 Hover-1 Charger Outer Shell Replacement: stap 12, afbeelding 3 van 3
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: stap 13, afbeelding 1 van 1
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: stap 14, afbeelding 1 van 1
    • Remove the left foot pad from the hoverboard.
Conclusie
Mark Rapiz
229 Reputatie
1 Handleiding geschreven
Cal Poly, Team S12-G1, Regan Fall 2019 Lid van Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Leden
6 handleidingen geschreven
Één opmerking
Where do I buy the shell their website doesnt have it
firestineanthony - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 531
