Inleiding
This guide will walk you through replacing the battery in your Hott T725-8G.
Wat je nodig hebt
Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
Één andere persoon heeft deze handleiding voltooid.
