Inleiding
Before beginning any of the following power switch replacement steps ensure that the device is not plugged into a power source, wear proper eye protection, and conduct the procedure in a well ventilated area.
Wat je nodig hebt
Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
Gereedschap gebruikt in deze stap:Tweezers$4.99
Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
Remove the power switch button exposing the electrically connected power switch.
