Ga door naar hoofdinhoud
Hot Tools HPK12 Heating Plate Replacement
Wat je nodig hebt
  1. Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: stap 1, afbeelding 1 van 3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: stap 1, afbeelding 2 van 3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: stap 1, afbeelding 3 van 3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Heating Plate Replacement: stap 2, afbeelding 1 van 1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Heating Plate Replacement: stap 3, afbeelding 1 van 2 Hot Tools HPK12 Heating Plate Replacement: stap 3, afbeelding 2 van 2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Heating Plate Replacement: stap 4, afbeelding 1 van 1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Heating Plate Replacement: stap 5, afbeelding 1 van 3 Hot Tools HPK12 Heating Plate Replacement: stap 5, afbeelding 2 van 3 Hot Tools HPK12 Heating Plate Replacement: stap 5, afbeelding 3 van 3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Heating Plate Replacement: stap 6, afbeelding 1 van 3 Hot Tools HPK12 Heating Plate Replacement: stap 6, afbeelding 2 van 3 Hot Tools HPK12 Heating Plate Replacement: stap 6, afbeelding 3 van 3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
  7. Hot Tools HPK12 Heating Plate Replacement, Heating Plates: stap 7, afbeelding 1 van 1
    • Lift plate and circuit assembly away from flat iron case.
  8. Hot Tools HPK12 Heating Plate Replacement: stap 8, afbeelding 1 van 1
    • Flip device to access the non-control assembly flat iron arm and remove two 3.5mm “J0” screws that attaches cover to flat iron base.
  9. Hot Tools HPK12 Heating Plate Replacement: stap 9, afbeelding 1 van 1
    • Lift cover from flat iron case.
  10. Hot Tools HPK12 Heating Plate Replacement: stap 10, afbeelding 1 van 2 Hot Tools HPK12 Heating Plate Replacement: stap 10, afbeelding 2 van 2
    • Lift heating plate away from flat iron case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nathan Schwartz
318 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-4, Baechle Fall 2016 Lid van IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 960
