Wat je nodig hebt
Unscrew the body using a philips screw driver.
Turn over and gently remove the body from the mechanism.
Recessed philips head.
Remove the motor mount philips screw and remove the gear covering.
Philips head screw.
Replace the body onto the loco and turn over gently.
Reassemble until step 5.
Move towards the trailing truck of the locomotive and remove screws.
Remove philps head screw.
Remove the trailing truck plate and remove the axle.
