Inleiding
It may be necessary to replace your vacuum belt if the brush roller is no longer moving (i.e., the vacuum is no longer picking up any dirt), your vacuum is extra noisy, or your vacuum is leaving a trail of debris. This guide goes through the step-by-step process of replacing the belt on a Hoover Windtunnel U6485900 vacuum.
No technical experience is required, and only a Phillips #2 screwdriver and the appropriate replacement belt are required to complete this repair.
Wat je nodig hebt
Turn off and unplug the vacuum, if necessary.
Lay the vacuum on its side, so you can see the bottom plate of the vacuum.
The reattachment of the bottom plate of the vacuum is included in this guide.
