Ga door naar hoofdinhoud
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
Wat je nodig hebt
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: stap 1, afbeelding 1 van 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: stap 1, afbeelding 2 van 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 2, afbeelding 1 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 2, afbeelding 2 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 2, afbeelding 3 van 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 3, afbeelding 1 van 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 3, afbeelding 2 van 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: stap 4, afbeelding 1 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: stap 4, afbeelding 2 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: stap 4, afbeelding 3 van 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 5, afbeelding 1 van 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 6, afbeelding 1 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 6, afbeelding 2 van 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: stap 6, afbeelding 3 van 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Conclusie
steven hoover
257 Reputatie
2 handleidingen geschreven
Cal Poly, Team S7-G2, Banghart Fall 2017 Lid van Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 43
Altijd: 3,979
