Ga door naar hoofdinhoud
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
Wat je nodig hebt
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: stap 1, afbeelding 1 van 1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: stap 2, afbeelding 1 van 1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: stap 3, afbeelding 1 van 1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: stap 4, afbeelding 1 van 1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: stap 5, afbeelding 1 van 2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chino Cruz
135 Reputatie
1 Handleiding geschreven
Cal Poly, Team S11-G4, Banghart Winter 2018 Lid van Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 53
Altijd: 4,779
